13v when warm
13v when warm
by tommycon45 » Fri Jun 23, 2006 11:13 am
hiya
as any1 else had this problem?
when start the car i`m getting 14v but 5 mins later when its warm it drops down to 13v, i had a eco which used to drop down to 11v until in temper i banged the fuse panel and every thing went back to normal tried banging this 1 with no result, don`t want to hit it any harder, ha ha.
paul
tommycon45
by CAL.16V » Fri Jun 23, 2006 12:03 pm
yeah mine seems to be at 14v when cold and drops when it gets warmer....
mine is a 95 turbo
around 13-13.5v when warm sometimes even 12.8-9 when some stuffs on like heated seats, demister, blower
CAL.16V
by tommycon45 » Fri Jun 23, 2006 4:57 pm
don`t make any differance if i rev the balls off it when its warm it still only gives out 13v max. tested it at the battery aswel and still only 13v. the eco i owned give 14v at the battery and 12v-13v on the in car voltmeter until i hit the fuse panel the 1 time.
paul
tommycon45
by Stupink » Fri Jun 23, 2006 5:41 pm
well if its 13 under load it doesnt really matter does it. if its dropping below the standing voltage of the system with only medium load then start to worry [img]/smile.gif[/img]
by boys_toys » Fri Jun 23, 2006 6:17 pm
put a volt meter across a good battery & providing the alternator is good you should get 13.5 / 14 volts on tickover ,so i thought . any less especially at higher revs one of them is on its way out or breaking down somewhere ...
boys_toys
by Animal » Fri Jun 23, 2006 6:33 pm
13v sounds about right.
by tommycon45 » Fri Jun 23, 2006 7:48 pm
not realy a problem at the moment for me but come winter when have lights, heated window and the blower on its not gona charge my battery. No good havin a calibra turbo that won`t start, LOL. i`l do another check tomorrow with the dig meter.
thanks for your input lads.
on a completely different note just watched NEWS on telly and there was cctv footage of 3 lads stabbing 2 other lads and they shot off in a blue calibra!!!!!!!
tommycon45
by M6 AXL » Fri Jun 23, 2006 9:33 pm
Mine does the same starts on 14v and after 5-10 mins drops a touch when warm. I was worried until I read this thread.
If the battery was overcharging wouldnt the engine management light come on?
M6 AXL
by boys_toys » Fri Jun 23, 2006 9:41 pm
14v is a healthy charge for a 12v battery, (with all lights , heated seats windows etc off) ... i drive a truck which is 24v the meter reads a healthy charge of approx 27v.... you must be putting more in than your taking out ...
boys_toys
by lammy » Mon Jun 26, 2006 9:56 am
Bleedin'ell..i've seen mine drop to 8!!! believe it or not and not with loads of ice..seems to have a mind of its own..will show 14 when started, especially on a cold morning..then hover around the 12 mark?
SE9
Users browsing this forum: No registered users and 57 guests
