I have a gremlin...
I have a gremlin...
...when I brake my offside side light comes on. Where's the best place to start looking to solve it? I noticed it on the way to buy some touch up pens from Half*rds so bought a new side light and it's still doing it. The side lights and brake lights work as they should do too :confused:
ross85
ross85
check all wiring connecters looking for a corroded connecter or broken wire etc, but it could be anywhere. try directly earthing the light cluster to the body, if everything works make it a pernament connection . i had the same on a vr6 turned out the earth spade in the plug had corroded away solved the problem as described making a direct earth.... good luck
boys_toys
<!--QuoteBegin-dicky+--><div class='quotetop'>(dicky)</div><div class='quotemain'><!--QuoteEBegin-->Take out the brake bulb that doesn't light and see if the side lights come on then.
Do the same with the otherbrake light if that does't solve it.<!--QuoteEnd--></div><!--QuoteEEnd-->
Just did this before I tried wiring in an earth, took the dodgy side out and the sidelight didn't come on. The bulb/holder is the outside one, the stop/tail one on the bottom row. Swapped the sides over for good measure and the brake bulb doesn't light up either on the other side. So I take it I need either a new bulb (which I'll get in the morning) or a new holder? When the dodgy bulb/holder is not in place the sidelight doesn't come on.
ross85
