C20LET ECU, Which chip is which?
Hi, I am in the middle (?) of uprating my Turbo. Have fitted a T3 turbo & 4 branch manifold and now want to fit phase 3 chips to help it all along. Problem is that I have had the chips for about a year and have lost the install guide. Having opened up the ECU I found there are no markings inside to tell me which chip is for the injection and which is for the boost control. The Chips I have to fit are marked ok but both are 14 pin so can fit either circuit board (a*se). Can anyone tell me which chip is which??? TA!!
4 X MORE
Hi, you can download the installation instructions from the site if they are genuine EDS phase3. (you will need more than to know which chip is which, so you might as well go straight there)
I think the phase1/2 install shows the chip orientation <a href="http://www.eds-motorsport.de/images/Anleitungen/EinbPh1-2-UK.pdf" target="_blank">http://www.eds-motorsport.de/images/Anleit...inbPh1-2-UK.pdf</a>
and then the power wheel install for the phase3 board and switch etc
<a href="http://www.eds-motorsport.de/images/Anleitungen/EinbDampfRadvEnglischV4+.pdf" target="_blank">http://www.eds-motorsport.de/images/Anleit...EnglischV4+.pdf</a>
Quick update. I have fitted the new chips and done a quick blast. All seems ok with the turbo / pressure. Spools up nice and boost is held ok. Not gone mad yet as I need to fit a fuel pressure regulator and sort out the wastgate etc but a quick run showing just over 1 bar boost was enough to prove a point.
4 X MORE
