Fault Codes 31 & 48
Fault Codes 31 & 48
Hello everyone,
Just done the paperclip test on my car and got fault codes 31 & 48.
48 is low voltage on the battery, which I think does need charging up. However, I don't know what to do about 31.
Recently, the car has been intermittently plagued by the ECU light coming on, at which point the car either loses power or cuts out. Not good, obviously.
If anyone can suggest a remedy for fault 31 I would appreciate it.
Cheers.
Cheers.
buzzaldrin
Why is the battery low? Has the alternator light been flickering on? Once they start to die it's better to just buy a new one TBH.[img]/smile.gif[/img] Yep, to clear the code disconnect the battery for a bit, or turn the ignition on and off 20 times.
