temp sensor for outside temp
is the temp sensor under the bumper common to all vauxhalls? showing -15,im in newquay at the moment and im sure it aint that cold,assuming its the sensor or could it be sumit else?
carson
its in the front bumper, this is taken from the guide to fit a cold air feed and
Finally the last step before you can remove the front bumper is to disconnect the ambient temperature sensor. Slide the front bumper a few inches forward carefully. Just to the right hand side there is a small sensor attached to the bumper it pulls out quite easily.
Cozy
<!--QuoteBegin-carson+--><div class='quotetop'>(carson)</div><div class='quotemain'><!--QuoteEBegin-->is the temp sensor under the bumper common to all vauxhalls? showing -15,im in newquay at the moment and im sure it aint that cold,assuming its the sensor or could it be sumit else?<!--QuoteEnd--></div><!--QuoteEEnd-->
Certainly the same as a mk3 astra as i have performed a swap on these
Rob
Rob
Users browsing this forum: No registered users and 74 guests
