High Voltage
High Voltage
Anyone had any experience of fault code 49?
Battery Voltage High?
Eml is on, but battery light behaves as normal.
Duke
You need to test the car ASAP with a multimeter to verify it is over-charging the batt. using it like this could damage electrical systems, so don't use it if you don't have to. The problem will be the voltage regulator on the alternator, so a replacement alternator is the easiest route.
The only importance is the belt pulley as far as i know, I think the others 90/120amp etc are all interchangable?? so just get the highest rating you'll need. I have a feeling late turbo's were all 120amp wide belt pully though, and the poxy early ones a pewny 70amp V belt. what year is yours?
you'll have the Vbelt 70amp then, it mounts differently also, so you'll probbaly need another the same, or look to modify a 120 which have the wide belt.
I found my 70amp ok when I had a Jplate, but I never had any aftermarket sound or anything like that. and rarely used the heated seats etc.
<!--QuoteBegin-Duke+--><div class='quotetop'>(Duke)</div><div class='quotemain'><!--QuoteEBegin-->Anyone had any experience of fault code 49?
Eml is on, but battery light behaves as normal.<!--QuoteEnd--></div><!--QuoteEEnd-->
Could be regulator that controls voltage sent to battery and car
Ian
Ian
MR_TOAD
Users browsing this forum: No registered users and 81 guests
