today i am mostly grr'ing at my ecu light
anyone with a magic wand or cystal ball or summat who can tell me why i have no ecu light!?!?
heavenly_d3vi1
ignition switch replaced 2 times... had no ignition switch when it started, stu hot wired it. as for whats been done recently, um... yeh well, melted a few wires, replaced a few wires... changed coil, the plug that goes on to the coil has no power, apparently all three wires in that plug are acting as an earth.
heavenly_d3vi1
<!--QuoteBegin-heavenly_d3vi1+--><div class='quotetop'>(heavenly_d3vi1)</div><div class='quotemain'><!--QuoteEBegin-->i dont suppose the accumilator bulb thingy 'swooshing' everytime the battery is related?
*clutches at straws*<!--QuoteEnd--></div><!--QuoteEEnd-->
you sure its not the fuel pump relay as if that is faulty or not working properly then the eml won't light up on the dash
Cozy
