electric window....
electric window....
by whamburto » Thu May 03, 2007 12:22 am
my passenger side electric window goes down ok but when tyrin to put it up it will go so far then start going up and down and up and down but will never close right-does any1 have an idea what it is?ive a p-reg 2.0l eco calibra....
whamburto
by mickeyboy » Thu May 03, 2007 4:38 am
<!--QuoteBegin-whamburto+--><div class='quotetop'>(whamburto)</div><div class='quotemain'><!--QuoteEBegin-->my passenger side electric window goes down ok but when tyrin to put it up it will go so far then start going up and down and up and down but will never close right-does any1 have an idea what it is?ive a p-reg 2.0l eco calibra....<!--QuoteEnd--></div><!--QuoteEEnd-->you mite want to try resetting them?to do this.close all doors and switch on ignition?close the window and press and hold down switch for a further five seconds and then repeat on the other window hope this helps.
mickeyboy
by Marc4X4T » Fri May 04, 2007 10:16 pm
Second, try pushing the round button next to the window switches at the same time you press the window switch. The window has a safety feature when it feels resistance, (rubber gasket around the window, someones arm, head...ect) the window will automatically reverse direction and stop. Its to prevent things from getting closed in the window.
While depressing the round button and the window switch the same time, the window will raise to the full closed position overriding the resistance.
Try this, see if it works.
Marc4X4T
by whamburto » Sun May 06, 2007 12:47 am
cheers boys-have tried 1st suggestion-no luck-will have a go at 2nd and let u no what happens-thanks for replying and for the help
whamburto
