Battery Drain max mA rating...
Went to swop cars over tonight to get the six ready for PVS, turned the key in the ign, and, click nothing.....
Disconnected the neg batt lead and checked for a current drain. Reading of 67mA. IIRC this is within allowed tolerance.....
Just trying to see if flat battery is due to lack of use (hopefully)
Now just got Saturday to sort the car before PVS...... starting to panic a bit....
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Had problems with mine a few weeks back, bloody thing would not hold a charge so I went and got a new and seems fine now.
Well charging the battery today at work so should be ok for the weekend. (same battery as VW Sharan diesels
which only just fits the calibra battery tray :icon_mrgr )
Also 'found' a mahooosive 640 CCA (cold crank amp) 80Ah battery which is an inch and a half longer, so will charge that as well, sling it in the boot and bring with a set of jump leads. Just in case.....
I now own this one.
I now own this one.
Mine goes totally flat after a week of non use.
Once a lead/acid battery has gone through a deep discharge (down to below 30% of full capacity) it will be irreparably damaged and will no longer hold a decent charge.
£30 gets you a new battery and then remember to disconnect it if not using it for a few days.
daddycool
Mark the booster pack is all charged up and I will be taking it with me.
Users browsing this forum: No registered users and 88 guests
