My electric window prob....
by hormonedmonkey » Wed Aug 01, 2007 9:28 pm
Hello.
Right peeps.
My drivers side window has decided to stop working, and the a few days later it worked again, the it didn't work for 3 weeks or so, worked for a day now doesn't again.
I've changed the switch with no joy, any suggestions what to do next?
Ta!
hormonedmonkey
by Stupink » Wed Aug 01, 2007 9:34 pm
check the big loom connector where it goes from the shell to the door, unplug it and make sure its nice and dry and not corroded. give it a good clean up if it is and some wd or similar... probably the heavy rain getting in there.
by hormonedmonkey » Wed Sep 12, 2007 9:59 pm
all seems fine. any other ideas?????
hormonedmonkey
by Stupink » Wed Sep 12, 2007 11:19 pm
the controller board on the motor inside the doors are prone to fail too, theres also a connector going to it that can sometimes get damp. but from the intermittant nature im not sure if ti would be the board failing..
When i ahd problems i got hold of another winder motor and plugged it in and tried that.. so i knew the problem was with mine.
