Window stuck
Window stuck
by ross85 » Fri Oct 26, 2007 10:55 pm
My passenger window opened itself earlier - it's now open half an inch and I can't get it to shut. Where's the best place to start looking for the problem?
ross85
by andy1 » Sat Oct 27, 2007 3:10 am
does it go up then drop, if so you need to press the littell button just by the window switch as you send the window, hope this helps
andy1
by ross85 » Sat Oct 27, 2007 11:52 am
Yeah I've already tried this but think there must be a problem with the motor/regulator as I can't hear it trying to work. Took the door card off yesterday and had a quick look but it seems awkward to get to the window mechanism.
ross85
by MickM » Wed Oct 31, 2007 12:09 pm
You might want to check for voltages and stuff under the button panel. It's easier than starting with the door. As you've already discovered, it's a pain...!!!
MickM
by ross85 » Wed Oct 31, 2007 7:21 pm
OK then cheers, will have a look tomorrow. At least I have a spare set of switches :)
ross85
by Leigh » Fri Nov 02, 2007 2:00 am
Fuse?
Leigh
by ross85 » Mon Nov 26, 2007 11:28 pm
Fuses and switches check out ok, pretty sure it must be the motor/regulator then. Is it at least possible to shut it somehow? The missus is driving it now and moaning about being cold :P
ross85
by tazz666 » Mon Nov 26, 2007 11:54 pm
high there mate it sounds like the stat for the window motor, it is bolted to the window motor its a pain to get to , but it has 4 torqs bolts holding it in to the motor it looks as if it is part of it but there was a recall on this part years ago because it did what your window is doing
by ross85 » Tue Nov 27, 2007 12:18 am
Cheers bud will check it out tomorrow
ross85
by ross85 » Mon Dec 17, 2007 8:01 pm
Right this is turning out to be a bit of a pain. Finally got round to checking it out tonight and it's impossible lol - my hands are too big! Is there at least any way to shut it for now?
ross85
by will73 » Mon Dec 17, 2007 10:49 pm
tap the button loads of times and window will go up just shut a small bit each time
will73
Users browsing this forum: No registered users and 82 guests
