fuel guage
fuel guage
by clark607 » Sun Nov 18, 2007 9:19 am
What can i check if the fuel gauge has stoped working?
i currently have a starting problem as well could they one of the same problem.
with the starting fault i have changed....
1. fuel relay
2. battery
3. starter motor.
possible alternator fault? and ideas?
clark607
by BazV6er » Sun Nov 18, 2007 1:06 pm
also you can check number 2 fuse as i had this happen when i blew a fuse when i shorted one.
by clark607 » Sun Nov 18, 2007 3:50 pm
cheers will have a look, but any other ideas if thats not the case?
clark607
by Calibra_Mike » Mon Nov 19, 2007 11:54 am
You're know if its an alternator problem if you charge the battery up and then go for a drive, you;ll get about 15mins of driving time before the battery dies...
If you charge the battery fully out and then its still not starting then it wouldnt be the alternator... more likely to be fuses, relays or wiring, check the earth connection first...
Do you get the engine check light come on at all?
As for the fuel gauge, could be the the sender unit, or a loose connection somewhere...
Electrical problems are normally either an easy fix or a nightmare but the only way to get them sorted is to go through a process of elimination...
Have you changed anything electrical in the last few days? installed any audio equipment or rewired anything? Do you have an alarm fitted? Could that be causing the non starting? Does it turn over or are you getting nothing when the key is turned?
