Battery
Battery
I have one of these GO type batteries from Vaux. The little indicator thing is showing black instead of green. I take it it needs charged or my alternator is slowly failing. I do have a problem with a badly slipping Auxillery belt at the moment so think this could contribute some what.
Have had no electrical problems as yet and just finding time to change the belt. The horrible high pitched whine at start up is getting embarrassing.
Rob
Rob
The battery started to fail a few days back, warning lights started to glow slightly whilst on the M1 in rush hour traffic so managed to get home just.
Replaced the alternator yesterday, bugg*r getting it out the car without re-positioning hoses, wiring, finger nails, skin.
New one in place, started up and still high pitched squealing, sounds as if it could now be power steering pump as the squealing also occurs when turning the steering to full lock and slightly apparent on acceleration.
Checked fluid levels in resevoir and looks ok, steering not getting heavy so wandering if it is just the pulley wheel. Are there any checks that can be done on the pump to see if it has failed bearings?
Rob
Rob
