what seems to be wrong with my interior light
by BazV6er » Tue Nov 27, 2007 9:08 pm
ive got a blue led a few years ago from tim2001 and it always worked and over the last few weeks ive needed a interior light sometimes the light has come on , sometimes gone dimmer and finally tonight theres no light
any suggestions?
by Calibra_Mike » Wed Nov 28, 2007 1:01 am
Are the LEDs on there way out, they dont last forever...
by Mark1 » Wed Nov 28, 2007 2:03 pm
He's right.
by BazV6er » Wed Nov 28, 2007 2:46 pm
is there a way to test them (mind you ive had them for a year or so)
by RobbieV » Wed Nov 28, 2007 3:52 pm
Buy another you tight git :D
by BazV6er » Wed Nov 28, 2007 9:50 pm
hehe .....
cheers guys (i didnt realise if the leds happen to go black like a normal bulb)
by BazV6er » Thu Nov 29, 2007 9:31 pm
what a surprise , tonight the led started glowing a bit and then went dim
by Phantom » Sat Dec 01, 2007 2:44 am
have you also checked the door contacts which operate the light, as they rust and give this sort of issue
Phantom
by BazV6er » Sun Dec 02, 2007 12:20 pm
no but thats a good thought cheers andy
by BazV6er » Tue Dec 04, 2007 10:40 pm
omg tonight its working fine now and bright as normal...
by BazV6er » Wed Dec 05, 2007 9:37 pm
well so far so good , lights are still working hehe
by jonboy78 » Mon Jan 21, 2008 10:19 pm
How much brighter are the LED lamps compared to the normal ones Baz??
jonboy78
by BazV6er » Wed Jan 23, 2008 11:26 am
pretty bright mate , look here mate:
http://www.freewebs.com/baz16v/modificationsspecs.htm
i did find out what caused this and it was all down to the alternator at xmas
by turbonut » Wed Jan 23, 2008 6:23 pm
they will run at about 4.5 volts leds usually do but they'll have a resistor built into the internal circuit so only the voltage they need can pass through leds will burn out very quickly if they get too much voltage my whole dash is proof of that (nightmare)
turbonut
by turbonut » Wed Jan 23, 2008 7:55 pm
the leds ive got are designed to run at 4.3 volts so they need to be used with a resistor to work they have a 35 degree viewing angle but in comparrison to a normal bulb they are blinding you are right about current but as long as the resistor is in series and not paralell to leds the change in voltage should not affect the led's
turbonut
