code 21
Which engine is this? the throttle position sensor is on the throttle body, voltage high usually means a break in the wire or the plug has come off etc..
the low oil level could be the sensor in the sump, or as simple as a break in the wiring again.. follow the wiring up from the sump to the first connefctor plug and unplug it, short out the two pins on the loom side the light should go out if thats ok, meaning its the sensor side.
