Brake lamp on dash
Brake lamp on dash
by jonboy78 » Fri Dec 28, 2007 8:29 pm
Hi all,
Sorry to be a pain in the a55 again but the brake warning lamp on the dash comes on as soon as I start the car. This has been the same since I got it. The lad who I bought the car off says that the handbrake cable needs sorting on the passenger side rear. Would this be the cause of the lamp being on? Its only because when I depress the brake pedal (I mean push it in - not tell it that it needs counselling or anything lol) the lamp goes out until the next time I start the car.
Any ideas?
Jon
jonboy78
by Tim2001 » Fri Dec 28, 2007 8:33 pm
Thats what its meant to do it checks ghat all the lights are working correctly. Once the brakes have been depressed the light goes out showing that all is well.
Tim2001
by jonboy78 » Fri Dec 28, 2007 8:43 pm
Yeah but surely the light shouldnt stay on until the brake is pressed?
jonboy78
by Tim2001 » Fri Dec 28, 2007 8:50 pm
Accept it mate its how it works
Tim2001
by jonboy78 » Fri Dec 28, 2007 8:52 pm
LOL - thats me told!!!
Just never seen that on a car before :) Always had cars that did an internal check and then flagged it up via the dash lamp if there was a problem.
Ok - am happy if thats the norm :) Cheers guys.
jonboy78
by Allys Cally » Fri Dec 28, 2007 8:54 pm
every day's a school day, eh jon :lol:
by jonboy78 » Fri Dec 28, 2007 8:56 pm
Which version of Vec? I have had a B-facelift one and a C.....neither did that! Vauxhall world is nuts! LOL! Not in a bad way - just very diff to the Ford world that I am used to :)
I am loving the Cally though - quick off the mark and lovely to cruise in :)
Ally - indeed it is mate! LOL! :)
jonboy78
by RobbieV » Fri Dec 28, 2007 9:03 pm
jonboy78 wrote:Just never seen that on a car before :) Always had cars that did an internal check and then flagged it up via the dash lamp if there was a problem.
That's exactly what the Calibra does - its called a check control system.
When the ignition is switched on all check control lamps light up, If all the monitored systems are ok they go out again after around 4 seconds.
The brake fluid level indicator goes out when the engine starts to run. The brake lamp indicator goes out once the lamps have been checked by the check control system following operation of the brake pedal.
by jonboy78 » Fri Dec 28, 2007 9:08 pm
Ahh ok fair do's!
Cheers for that fellas - thats one less "fault" than I thought it had lol.
jonboy78
by tango » Fri Dec 28, 2007 10:30 pm
check the break fluid it comes on when its to low
tango
