anyone got the haynes manual that covers...
by truxx » Thu Jan 10, 2008 8:21 pm
As above,need to find out which colour relay is for the radiator fan.
I know the relay is located behind the fusebox on it's own bracket,but the manual i have is for a cavalier and doesnt give any info about the fan relay...
On another thread http://www.clubcalibra.net/viewtopic.php?t=28055
Someone called CHIEF has posted some pics of the relay,but the link to the pics is dead...
Any help would be greatly appreciated..
Thanks
Dave
truxx
by ecosseM » Thu Jan 10, 2008 8:42 pm
does it have a relay?
not looked, but radiator fan switches on from a temp sensor in the radiator..
ie, if you want it to run all the time, you link those wires
ecosseM
by truxx » Thu Jan 10, 2008 9:13 pm
I didnt think they had one either...but yeah it definately has.
truxx
by ecosseM » Thu Jan 10, 2008 10:13 pm
just had a look in haynes.. from what i can see, its on the eco-tec the the v6.. maybe on ones with aircon..
cant see it being on the 8v, unless you got air-con in your se4
ecosseM
by truxx » Fri Jan 11, 2008 12:11 am
Well i dont have air-con so im not sure now.
The cavalier manual i have covers 1988-1990 and says all models have the relay,but they also say the relay is located in the box under the engine bay.
On mine i only have 1 30A fuse in there,but behind the fusebox(incar totally seperate to the fusebox) i have these relays:
I just assumed one of these must be it.
In the link i posted above someone (username chief) posted pictures of it,so if there is a relay on one model,i would imagine it would be the same on all models.
Seems a bit strange that there isnt much mentioned anywhere about these hidden relays.:(
This is sooo annoying :)
Thanks for the info
Dave
truxx
by fattyfattyboomalatty » Fri Jan 11, 2008 11:42 am
there must be a relay for it. the current draw from the fan would be too much to go through the switch otherwise.
by truxx » Fri Jan 11, 2008 1:17 pm
fattyfattyboomalatty wrote:there must be a relay for it. the current draw from the fan would be too much to go through the switch otherwise.
Yeah i thought as much :) thanks m8.
( i didnt want to ring you on tuesday m8,I thought it would be a bit cheeky of me to ask you to look at my car on your only day off :) )
truxx
by fattyfattyboomalatty » Fri Jan 11, 2008 1:23 pm
off on sunday too pal. gizza bell iif its still not sorted
by ecosseM » Fri Jan 11, 2008 7:33 pm
on the cooling fan on most of the models the fan is just basicly on/off... this is controled be the temp sensor on your radiator, which opens/closses at set temp and makes the circit to power up the radiator fan.
just out of interest, why you asking about this? whats the prob?
ecosseM
by truxx » Fri Jan 11, 2008 8:28 pm
Hi m8,
the problem is i cant get the radiator fan to work..
Tryed shorting the wires on the rad switch,fuse is ok,replaced the actual fan with a known working one...Still just wont work.
truxx
by truxx » Fri Jan 11, 2008 8:32 pm
fattyfattyboomalatty wrote:off on sunday too pal. gizza bell iif its still not sorted
Ok m8,
Will ring you on sunday/any preference ? morning afternoon?
Thanks
Dave
truxx
by ecosseM » Fri Jan 11, 2008 8:59 pm
you dont cross the wires on the fan..
you cross the 2 wires on the temp sensor on the radiator
ecosseM
by ecosseM » Fri Jan 11, 2008 9:00 pm
oh.. if i can mind rite... its the sensor on the drivers side of the radiator... 5 min job to do/ check
ecosseM
