Help pse?Brake Lights flash with Indicators.
by andym1fjg » Thu Feb 21, 2008 10:22 pm
Help Pse, my 93 calibra kept blowing a fuse when indicating & the fuse on the alarm, so only 1 side will flash, Ive had to put more amp fuses in but this is wrong I know, also now one side is duller then the other when the alrm is activated & while I indicate my brake lights flash with indicators??any Ideas pse tnx.
andym1fjg
by Allys Cally » Thu Feb 21, 2008 10:28 pm
check the bulb holders in the rear lights they might be corroded
by cally8valver » Thu Feb 21, 2008 10:30 pm
yep sounds like corrosion in multi plug to rear lights or bulb holders more common on old fords you know when you brake and they all light up like a christmas tree lol
cally8valver
by BazV6er » Fri Feb 22, 2008 12:16 pm
or a bad earth somewhere .
by Callyman » Fri Feb 22, 2008 1:24 pm
BazV6er wrote:or a bad earth somewhere .
What Baz said, irratic behaviour in a bulb cluster is nearly always a bad earth somewhere. To prove it, have the bulbs flashing and temp' hold a wire onto the earth side of the bulb connection and earth the other end to the body, this should prove if it is indeed an earth problem.
