Fuel pump problems.
Fuel pump problems.
by wcorkcalibra » Thu Apr 03, 2008 10:44 pm
Hi people,
I have a problem with the wifes '91 8v.
It was left standing for a while and when i tried to start her she fired but died, it would appear that the fuel pump isn't working.
Is this a common thing after being left standing and the battery going flat?
Any help would be gratefuly recieved.
wcorkcalibra
by Stupink » Thu Apr 03, 2008 10:53 pm
no not a common problem for the pump to die, but there is a common problem with the fuel pump relay.
you can identify if that is the cause because the ECU light shoudl come on when you first put the ignition on before trying to crank, if it doesnt, then its because of the relay.
welcome to the site :)
by wcorkcalibra » Thu Apr 03, 2008 11:02 pm
Thanks for that, I'll check 2moz
wcorkcalibra
by wcorkcalibra » Thu May 01, 2008 11:47 am
Hi again,
The story so far.
The fuel pump relay has been replaced, no difference.
'FI' fuse checked, was fine.
Fuel pump works with 12v straight to it, still no fuel to engine.
PLEASE HELP!!
wcorkcalibra
by wcorkcalibra » Thu May 01, 2008 12:03 pm
The ECU light is on until she cranks, will check what other lights are on.
what you mean by codes?
The terminals are a bit corroded, will either clean them or replace them later.
wcorkcalibra
by Callyman » Thu May 01, 2008 12:09 pm
by Phantom » Thu May 01, 2008 1:18 pm
also worth replacing the fuel filter, can you hear the fuel pump working?
Phantom
by wcorkcalibra » Thu May 01, 2008 1:21 pm
Fuel pump runs fine with 12v straight to it yes.
wcorkcalibra
by Phantom » Thu May 01, 2008 1:24 pm
if there's no 'supply' to the pump when you crank the engine and the relay is ok I'd suspect the immobiliser
Phantom
