c20ne engine loom
c20ne engine loom
by markib » Fri May 09, 2008 1:46 pm
it's from a 89 astra gte
is this a full engine loom if not what do i have missing....?
would i need to get another loom and ecu or could i just get the rest of the loom to just plug at the black connector cas i think i have a fuel relay and lamda sensor plug missing(i was told that the code FF on the ECU is a none lamda model) and the main feed from the starter to the ecu is missing
if any 1 could help me out either with info,pics or another loom or what i have missing on my loom that would be brill
markib
by Calibra_Mike » Fri May 09, 2008 1:55 pm
I dont think that is the full loom, not sure whats missing, Ill have a look later tonight...
by markib » Fri May 09, 2008 9:40 pm
so any ideas :roll: :roll:
markib
by Calibra_Mike » Sat May 10, 2008 10:12 am
Im pretty sure your missing the Air Flow Meter plug/cable and the wire that goes to the thermostat housing... theres a few other wires that should be over on the right by the arrow ive drawn in, try and see from this pic...
by markib » Sat May 10, 2008 11:12 am
hi mike thnx for the reply
the two leads u mention on the left hand side are on my loom(air flow meter and thermostat) the right hand side of my fuel rail finishes at the black plug in the picture
over on MIGWEB i was told"you are missing the mini loom for the ICV and knock sensor it clips into the big multiplug at the end of your injector loom
so is this rite....how much more loom should i have on the right hand side of the fuel rail......
markib
