Fuel range calibration
Has anyone got the link or info on how to calibrate your fuel range on the trip computers. As mine reads 130 miles when its in the red deffo not correct even for a V6
cornishtaz
can do it on any of them....but if the chip is not the correct one for the car then the range is always going to be way out
before I go and try the range adjustment I think I would check the chip code first (not you Ian)
IIRC hold both buttons down..turn ignition on should then display the code and on the top along with some other info at the bottom..let go and you get another set of numbers
post that here and will look it up
