Let loom diagram
Let loom diagram
by bodgetastic » Sat May 31, 2008 5:30 pm
Anyone any ideas where the switched live connects on the below diagram?
Also does anyone have a similar diagram for the other loom?
Site Moderator
Site Moderator
by Sean C » Sun Jun 01, 2008 3:27 pm
I have looked on mine and it connects in to the large round connector behind the battery ( the one with the red clip you push before you can twist it to pull it apart) There should be a black wire coming from that with a single connector on it
by bodgetastic » Sun Jun 01, 2008 3:37 pm
Sean C wrote:I have looked on mine and it connects in to the large round connector behind the battery ( the one with the red clip you push before you can twist it to pull it apart) There should be a black wire coming from that with a single connector on it
Cheers for looking Sean, are you referring to the switched live? I'll have another look but I have connected it to the other loom by the battery so sounds the same place.
Site Moderator
Site Moderator
by Sean C » Sun Jun 01, 2008 4:01 pm
Yes mate i looked for the switched live marked on your diagram
Users browsing this forum: No registered users and 68 guests
