ABS, reverse lights and high beam....
3 questions....
ABS
I had to lock-up the other day in my calibra to avoid a crash-and-burn happening, however my abs didn't work! Instead i have flat spots on all 4 tires any idea why the abs never kicked in? I have checked my fuses and none are blown.
Reverse Lights
My reverse lights work when they want to. I'd say 2 out of 3 times they DON'T work, I've pulled the clip out of the gearbox and cleaned it and put it back but still no good.
High Beam
Also my O/S high beam doesn't work so removed both bulbs and switched them over, still didn't work with another bulb, and the bulb i suspected broken didn't work in the N/S. That means that both the connection and the bulb didn't work though the bulb doesn't look broken upon inspection..very puzzled any ideas?
Joker
ABS
Reverse Lights
High Beam
Joker
Joker
DC 12v
Joker
pr0xZen
pr0xZen wrote:Regarding reverse lights - any corresponding issues with Fuel computer and/or it's backlight?
come again?
I'll take the dash out and have a look see if there is a bulb in there, There are signs of attack with the screwdriver around the dash lol. Will take alook and get back 2 you. If the light has been removed what will that mean? other than it must have been on, but does that mean its foobered?
Joker
Joker
ABS could be down to a few things, Bulb, Sensors, fuses etc... check the bulb first, I had a problem with this and it turned out to be a crack in the track on the back of the dash circuit bit... bit of solder later and it was working again...
