busted abs sensor
busted abs sensor
by casper81 » Sun Jul 20, 2008 1:35 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 26_fvi%3D1
dunno if that will work for you's but im wondering if it will be ok to fit this to my 8v calibra? was told my sensor had coroded cheers for any help on this one
casper81
by big_gordy » Sun Jul 20, 2008 3:44 pm
i dont think so but i usually wrong......lol
Tigra Chequers 1.6 - # 2 Car
by casper81 » Sun Jul 20, 2008 10:55 pm
lol ah well. was kinda hoping they'd be a universal fit
casper81
by JohnD » Tue Jul 22, 2008 12:58 am
It's not normally the sensors that go wrong, it's the toothed rings that corrode & cause the problems. I seem to remember there's a guide that tells you how to measure the resistance of the sensor using a multimeter. Just unplug it up inside the wheel arch and measure it, if the reading falls inside a guide range then the sensor will be ok, you can measure it for Ohmic Resistance & then set the meter to the AC Voltage Scale & rotate the relevant roadwheel at approx 60rpm & note the multimeter reading. If all's not well then you're looking at changing the toothed rings.
JohnD
