Fuel pump relay
Fuel pump relay
Has anyone else had trouble with there fuel pump relays? also, i seem to have 2, drivers side kick panel, purple ones?
Replaced one, but still have trouble starting sometimes, i think it must be the relay as i've left the panel off and can hear them click when it finally starts or is there something else that does the initial 'prime' to start the car?
Just wondered before i go buy another one!
roboliver
there will be only one, but there are several relays that do different things.
the tell tale for the fuel pump relay causing starting issues is that the ECU check control light won't come on as normal before starting. tap the relay untill the light comes on, and then the car will start.
roboliver
