Electrical problems for my new Calibra
by Martyn77 » Tue Oct 28, 2008 10:39 am
I've just bought a 2.0 8v Calibra of a friend and it has a slight electrical issue, when turning the ignition off the battery light stays on. They were told this was the alternator but i think it's an earth problem. She had bought a new battery for the car about a month ago so it's not a battery issue, i have since been told that the engine management light is coming on aswell so any info would be much appreciated, cheers, Martyn.
Martyn77
by BazV6er » Tue Oct 28, 2008 12:18 pm
martyn ,
i had a diode burn out in a alternator in a previous calibra 16v and that made the engine management light come on and it did need a new alternator in the end.Have you tested how many volts its giving you ?
by Markp » Tue Oct 28, 2008 12:45 pm
Check and clean all of the main earth's including the alternator one. Should that fail then run the paper clip test and see what reading your getting. By this stage you've not spent any money so if you need a new alternator it won't hurt as much. Maybe borrow an alt from a friend and test that?
Markp
by Martyn77 » Tue Oct 28, 2008 2:11 pm
Thanks guy's, i've not picked up the car yet as i knew it had an electrical problem but i'm not going to complain as i'm getting it for £150 with 6 months MoT and Taxed til the end of next month. I'll probably just pick up a re-con alt and check all the earths when i get up to the car.
Martyn77
by Phantom » Tue Oct 28, 2008 11:11 pm
if the batt light is on after you turn the ignition off it's a sure sign the alternator needs replacing I'm guessing it flattens the new battery over night too
Phantom
by Martyn77 » Wed Oct 29, 2008 12:08 am
Cheers guy's your input is much appreciated, i've priced up some re-con altenators and hopefully i'll have the car on the road in the next week or two.
Thanks, Martyn.
Martyn77
by VII CKS » Wed Oct 29, 2008 11:25 am
Definately sounds like the alternator to me too, you can get a reconditioned one as you are looking for and if you get one in Halfords if there is one up near you, you can trade your old one in for £25 of the price of the reconditioned one.
VII CKS
by Martyn77 » Wed Oct 29, 2008 12:46 pm
Thanks i'll get onto them asap
Martyn77
