Heated seats not working
by J3LLY » Wed Dec 31, 2008 12:37 pm
'97 V6. At a loss as to why tried all the obvious any advice welcome. J3lly
Re: Heated seats not working
by Mark1 » Wed Dec 31, 2008 12:43 pm
If you have check the switches, wiring, relays and fuses it could be the pads themselfs that have had it.
Oh and Hello and welcome:wave:
by J3LLY » Fri Jan 02, 2009 12:28 pm
What relay's and fuses should I be looking at
by Fraz » Fri Jan 02, 2009 12:31 pm
are both seats not working or just one? most common problem is the wire breaks just at the seat back at the pivot point for the seat to tip forward.
list of fuses
knowledge/kb_show.php?id=15
by J3LLY » Fri Jan 02, 2009 6:08 pm
Its both seats not working have checked fuses and relays all appear OK.
Switches illuminate when pressed.
Will check wiring for breaks as described.
Should both the seat and back heat up.
Regards Gary
by Fraz » Fri Jan 02, 2009 6:36 pm
yes back and seat bit both heat up, would check that
A. the switch's are properly connected
B. the connector under the seats are connected
if they are get your self a test light and see if your getting power at the connector under seats
by Phantom » Wed Jan 07, 2009 7:41 pm
I had the same problem and its the heater pads that are broken
Phantom
by vaggelis00 » Wed Jan 07, 2009 10:16 pm
and what did you do with the pads?
vaggelis00
by Ace_aka » Fri Jan 09, 2009 2:28 am
have the same problem, never worked since i bought the car 3 mths ago but now getting a bit nippy so could do with heated seats. switches light up put no heat, so what should i check first? cheers
Ace_aka
by Fraz » Fri Jan 09, 2009 3:51 pm
Ace_aka wrote:have the same problem, never worked since i bought the car 3 mths ago but now getting a bit nippy so could do with heated seats. switches light up put no heat, so what should i check first? cheers
could try reading this post from the start
by cornishtaz » Fri Jan 09, 2009 5:04 pm
Check both connections under the seat if these are connected make sure you've got 12v at this point. If all ok then check the wiring as it passes next to the pivot points and is very prone to breaking, this happened on my passenger seat so I had to resolder the wires now all ok
cornishtaz
by vaggelis00 » Thu Sep 10, 2009 6:56 am
is it possible to replace the heating pads? has anyone done it? are the pads alone available for sale?
vaggelis00
by tazz666 » Thu Sep 10, 2009 9:34 am
to answer both your questions ,,,yes to both :D
by vaggelis00 » Thu Sep 10, 2009 11:09 am
where can i find the pads?
vaggelis00
by vaggelis00 » Thu Sep 10, 2009 11:33 am
i've checked the wiring and everything seems ok. but the seats are not heating. so propably the pads are off. where can i find new pads?
vaggelis00
