Windows only operating when door switch earths ??
I would appreciate some expertise I have had everthing apart looking for the problem , but can't work it out
Many thanks,
Bobby
bobbydazzler
Re: Windows only operating when door switch earths ??
also check the door connector itself, the plugs often get water in them and corrode, give it a good clean and go from there
no need to strip the door down for that.
also does it do that with just one door or both?
vinny_69
It does it on both windows. You can see the windows bottons on the centre consol light up once the door opens. Then when closed they go off. I disconnected the door connecter and reconnected it. I have looked at the fuses in the fuse box and swapped them.
Also I have noticed my electric wing mirrors are not now working.
bobbydazzler
so you have changed the relay then,does it work?
vinny_69
Just been outside and rechecked fuse box. There was a 2nd window fuse -replaced this - cleaned the door connectors and bingo. All working again. Including mirrors.
Thanks very much for your help,
bobbydazzler
