bit of alarm help please!!
by boyracernbr1 » Mon Jan 26, 2009 7:11 pm
ive wired up a after market alarm to me cally and want to wire up the alarm so the fob locks the doors aswel, anyway cut a long story short i got the two wires of the alarm that are supposed to go to the drivers solenoid and put a tester to them expecting a surge of voltage or something when i blip the fob but nothing,any help on this or even better an alarm fitter if there is one on here, thanks
boyracernbr1
Re: bit of alarm help please!!
by tazz666 » Mon Jan 26, 2009 7:23 pm
what alarm have you got and are the wires for the locking system supposed to be for the locking?
by Fraz » Mon Jan 26, 2009 8:28 pm
The alarm locking pulse is an earth, so you wont get any voltage reading (unless your using a meter for testing or a smart tester))..and you should run wires form the alarm to the central locking relay ....not the solenoid
most alarms have either a positive or earth pulse option ...if you have used a positive to the solenoid you may have damaged it now
also now moved to the correct forum :)
ps if your not sure about car eletcirc.s...best leave them alone, could cause more problems :!:
