traction control
traction control
as you all know i converted the redtop into a v6, using all the v6's wiring looms so i could have traction control
but since it has been back on the road it t.c hasnt worked , so i pulled the bulb from the telltale bulb from the dash, all is fine just recently the car has been holding back under full throttle , just now and again . while i was checking all the fluids and such i moved the tc arm one from the motor to the throttle body and i got some resistance which was the first time since the conversion.so i put the bulb back in and pressed the tc button and low and behold it works. so i take it i will have to reprogramme the tc ecu , to stop it from coming on while accelarating?:D
Re: traction control
i think you can reset the tc someow mate but i cant remember
anyone got the link?
vinny_69
