Earth lead
Earth lead
Does anybody know the length of the main earth lead from the battery negative on a V6 ?
Re: Earth lead
You've got one go and check it.
Re: Earth lead
Mark1 wrote:You've got one go and check it.
If i could get under the car to check how long it is and where the end is i would
Re: Earth lead
chaos wrote:it will end on your starter motor iirc
You sure?
Re: Earth lead
chaos wrote:well it did on my last car (veccy)
Think you'll find that was from the + on the battery, but might of had a black insulation around it.
Re: Earth lead
Could well be mate, if that is the case then i have no idea, sorry for false info guys
chaos
Re: Earth lead
ive tried having a look for the dimensions rob but havent found anything yet online.
Re: Earth lead
BazV6er wrote:ive tried having a look for the dimensions rob but havent found anything yet online.
Prob never will tbh.
Re: Earth lead
RobbieV wrote:If i could get under the car to check how long it is and where the end is i would
It's your lucky day MrV....
The main earth bolts to the front of the engine block (big ring terminal - 17mm bolt iirc) and is approximately 37 inches in length give or take a couple... (it's a bit bendy)
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Re: Earth lead
Cheers Mark, have got one coming in the post soon to change over
