engine management light comes on
my engine management light sometimes comes on then goes off after a while. it does'nt seem to affect performance or anything or have any problems.
any salutions of what this could be.
i have a 1990 2.0l 8v calibra.
cheers rich
cheers rich
R1CH1985
Re: engine management light comes on
should be able to read the codes off that engine so then you'll know exactly what it is
short pins A and B on the diagnostics plug and count the flashes, search for the "paperclip test" on here for full details
likely causes aging lambda sensor if mostly uphill.
ok i'll give it a try and ive just found this site aswell.
my be usefull or some may know of it already.
www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
R1CH1985
