Help with connection, please...
by Dorca » Fri Aug 21, 2009 12:45 pm
Hello friends, I am not sure I made the connection, can you help?
I get an "F" in the onboard computer to shut down the engine.
This is the pattern of connections:
So I connected like this:
From car____________________From central
No connect----------------------Orange
Brown-White-------------------White-Black (open signal)
Black-----------------------------Yellow (negative battery)
No connect---------------------Orange-Black
Brown-Red---------------------White (close signal)
Black-----------------------------Yellow-Black (negative battery)
Black-----------------------------Black (negative battery)
?-----------------------------------Red-Black
Red-------------------------------Red (positive battery)
?------------------------------------Pink
L on emergency button------------Brown (Intermittent) left
R on emergency button------------Brown (Intermittent) right
Brown-Black-----------------------Green
Thank you very mucht!
Dorca
Re: Help with connection, please...
by Dorca » Fri Aug 21, 2009 3:45 pm
Well well ... gremlings more?
Now when you want me brand bulb brake failure in the table, the bulb is not well founded.
After turning off the car and switched on the moment, does not mark a failure, but during the driving when I least expect it again.
Now also mark the table (intermittently) failure in the rear lamp.
So out of the bad connection and remote control that I tend to find something in the wiring of the car.
I checked the rear lamp holder and seems well
Thank you
Dorca
