Knock sensor wire
Knock sensor wire
by ste_goffy » Mon Sep 28, 2009 6:41 am
where does this plug into
i have looked all over the engine bay now and i cant see or find where it could plug into?
i have all the other wires connected bar this 1
ste_goffy
Re: Knock sensor wire
by Mark1 » Mon Sep 28, 2009 8:43 am
It's located at the lower inlet manifold side of the block, below the the idle speed adjuster, and is only accessible from below. Thats for the C20XE and X20XEV.
by Fraz » Mon Sep 28, 2009 9:35 am
what engine are we on about then??
by ste_goffy » Mon Sep 28, 2009 4:34 pm
yeah all sorted on the engine swap,
then only wire i have left is the knock sensor wire, its not the sensor position thats the problem, its the connector ie the part that plugs into the car loom
ste_goffy
by Stupink » Mon Sep 28, 2009 6:12 pm
As im still not sure on the engine, or to be honest the question. as you do ask where the wire goes. and the wire goes to the knock sensor lol. but you say you know where that is lol. so i'll just say what its like on an XE and LET and maybe it iwll help
The sensor in the location mentioned above (around cylinder 3) is very small and has the connector as part of it without any wire.. this has a red plug that connects to it, which comes off the small loom that also has an identical black plug on it which should go to the idle control valve. the other end of this short Y piece goes into a plug connected to the loom that is a flat connector with about 4-5 pins and comes out the loom on the passenger side of the injector rail as you follow it away.
by Fraz » Mon Sep 28, 2009 8:18 pm
ste_goffy wrote:yeah all sorted on the engine swap,
honest it will help if we know what engine your on about
by ste_goffy » Mon Sep 28, 2009 8:40 pm
sorry guys its an ecotec engine
ste_goffy
by ste_goffy » Tue Sep 29, 2009 10:30 pm
i will take some pictures of the wires im on about tomorrow night and post them,
that connector with the 4-5 pin connector on is plugged into the loom that goes to the starter iirc.
i could be wrong, will check tomorrow tho
ste_goffy
by Fraz » Wed Sep 30, 2009 6:24 pm
sorry never worked on an ecotec other than rip them out engine bays...and we never noted the wires
by ste_goffy » Wed Sep 30, 2009 10:12 pm
thanks peeps
ste_goffy
by Fraz » Sun Oct 04, 2009 5:33 pm
oh dear :axed:
by v6 steve » Sun Oct 04, 2009 5:33 pm
:lol: :lol: :lol:
which one is it and ill go back down and take another
by Fraz » Sun Oct 04, 2009 5:34 pm
knock sensor....you should know where they are :D
by v6 steve » Sun Oct 04, 2009 5:37 pm
isnt there two?
by Fraz » Sun Oct 04, 2009 5:38 pm
no only one ..its not a V6 :)
