ABS Light coming on
ABS Light coming on
by Callyman » Thu Dec 31, 2009 2:01 pm
Over the last few days the ABS light has been coming on now and then, when i turn the car off and restart it goes out but then can come on again when it feels like it.
Is this prob just some dirt etc on one of the toothed rings?
Re: ABS Light coming on
by Fraz » Thu Dec 31, 2009 2:07 pm
read the fault codes and see what they say
by Callyman » Thu Dec 31, 2009 2:11 pm
What pins do i short to read ABS codes?
by Fraz » Thu Dec 31, 2009 2:20 pm
Pins A+K
16 LH Front Solenoid ( Relay & Connections )
17 RH Front Solenoid ( Relay & Connections )
18 Rear Solenoids ( Relay & Connections )
19 Solenoids Relay Circuits
25 Faulty Sensor toothed Ring
35 Pump Relay Circuits
37 Stop Lamp Switch ( Pedal Switch )
39 LH Front Speed Sensor ( Air Gap & Operation )
41 LH Front Speed Sensor ( Resistance & Connections )
42 RH Front Speed Sensor ( Air Gap & Operation )
43 RH Front Speed Sensor ( Resistance & Connections )
44 LH Rear Speed Sensor ( Air Gap & Operation )
45 LH Rear Speed Sensor ( Resistance & Connections )
46 RH Rear Speed Sensor ( Air Gap & Operation )
47 RH Rear Speed Sensor ( Resistance & Connections )
48 System Voltage High/Low ( Alternator & Battery )
55 Faulty ECU
