ECU flashing/ fault reading?
Please bare with me as I have never had to do this before.
I decided to run take the Calibra to work today to give it a run. On the way home the engine magement light came on
I thought I would have a go at reading the fault codes. I found this site to help me:
http://everything2.com/title/How+to+rea ... me+GM+cars
Is this correct? only when I fash mine it flashes 10 times, pause, once, pause, then flashes again 10 times.
Any help would be very much appreciated and if any one has a better set of instructions or list of fault codes to the one on the site above it would be a great help.
Thanks in advance.
Thanks in advance.
Magnetic blue SE8
Diamond black turbo 4x4
Magnetic blue SE8
Re: ECU flashing/ fault reading?
try this site
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
If your still having trouble, give me a shout...
Dammit MrV
But I'm closer
Dammit MrV
But I'm closer
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Thanks guys I will have a read through and have another tomorrow as ive got day off work and will have more light to seee what im doing. I will let you know how I get on. I will let you kow if i get stuck Mark.
Magnetic blue SE8
Magnetic blue SE8
I finally managed to get out and look at the cally today. Got the hang of flashing the ECU now. The web site above helped alot. Shows up fault code 13 (oxygen sensor). Checked the connection and seems ok. So I guess the sensor is worn out. I will get another one from Vauxhall tomorrow. Also did a few other bits and pieces too.
Magnetic blue SE8
Magnetic blue SE8
pretty good hey james , and just with the aid of a paperclip saves paying £50 for a diagnostic at a specialists.
Yeah it sure is Baz. Thats £50 I can put towards something better for the cally. Thats if the missus doesn't find it and spend it
Magnetic blue SE8
Magnetic blue SE8
cost you £70 for a new Lambda..well if you buy a Bosch one that is
Is that with club discount Fraz? Still better than if I had the fault code read at Vauxhall.Fraz wrote:cost you £70 for a new Lambda..well if you buy a Bosch one that is
Magnetic blue SE8
Magnetic blue SE8
no if you go to vauxhall you better sit down, last time I went it was about £200 there
No I got mine from this place
http://www.lambdasensor.co.uk
That just seems a rip off!
Thanks I will bare that web site in mind. Think it might be a trip to the local breakers yard first to see what I can find, they've usually good range of Vauxhalls in.
Magnetic blue SE8
Magnetic blue SE8
oh I would not be fitting a used one, they are considered a serviceable item and should really be replaced roughly ever 5 years anyway
Ok, thanks Fraz. On that advice I will get a new one then. At least then I won't have to worry about it.
Magnetic blue SE8
Magnetic blue SE8
