Little f
Re: Little f
It means there's a fault.
Does it still work ok? or is it just an F?
If so it's poss outside temp sensor.
Mine has a very small F in it when ignition is off, but goes when i start it.
Re: Little f
Erm everything works fine (touchwood) just this little f flash's prettymuch all the time now, so its just a fault with the trip/clock comp then?
Re: Little f
Try removing the plug from the rear of the unit and refitting it, that sorts mine out for a while.
Re: Little f
Will do thanks for that.
