Erratic Rev Counter.
Just noticed that anything above 3000 rpm then the rev counter goes nuts, like bouncing off the limit of where the needle reaches, soon as the engine revs drop around 3000 rpm or below its fine, checked leads and plugs all seem well and drives ok, checked on me apexi guage and this is reading the revs correctly, any ideas ?
Gaz
Gaz
LET the fun begin.
Re: Erratic Rev Counter.
Dodgy set of clocks?? If you've checked the connections etc, then there's not much left in the equation.....
superfox233
mines done that mate it was a faulty earth wire behide the fuel rail
bigdaz1987
cheers lads, will check the earth, is it the one to the left handside as you look at the engine.
Gaz
Gaz
LET the fun begin.
Checked the earth wire seems to be ok, had a split hose on the breather that goes to amal valve, seems to have settled the rev counter down, weird.
Gaz.
Gaz.
LET the fun begin.
