trip computer
trip computer
im thinking of putting in a trip computer to replace
the clock / temp guage
is it just a plug & play or is it more technical with the wiring?
what sort of money do they cost (with switch)
rob
rob
vcab1
Re: trip computer
if you have the elusive yellow plug taped up someplace behind the dash, also you will need to cut out the coin holder to fit the switch
Re: trip computer
Fraz wrote:if you have the elusive yellow plug taped up someplace behind the dash, also you will need to cut out the coin holder to fit the switch
had a look today, yes the yellow plug is there
vcab1
Re: trip computer
You will need like for like trip. Comp chip.i.e comp from a car with same engine type
k1nty
Re: trip computer
normally you can pick up the display and switch for about £30,have a look in a load of for sale ads on migweb,normally loads on there.
specks
