No reverse lights..........
by DOD » Thu Jan 06, 2011 7:30 pm
noticed this evening tht i've no reverse lights :shock: , i checked all the bulbs and they
all seem fine and tried reverse again but still nothing... Any ideas guys??
DOD
Re: No reverse lights..........
by RobbieV » Thu Jan 06, 2011 7:31 pm
Check reverse switch on the gearbox.
by DOD » Thu Jan 06, 2011 7:36 pm
can i do tht from inside the car mate? i.e lift the gaitor up?
DOD
by RobbieV » Thu Jan 06, 2011 7:41 pm
DOD wrote:can i do tht from inside the car mate? i.e lift the gaitor up?
No, its on the gearbox but not too sure where.
by stevo turbo » Thu Jan 06, 2011 8:42 pm
pull the plug off the gear box and it will be a 2 pin job. put a paper clip across it and put ignition on and if you reverse lights are on its a faulty switch. but dont start pulling plugs off everywhere and putting a paperclip in if your not sure which one it is though!
Club Member
Club Member
by DOD » Thu Jan 06, 2011 9:54 pm
any idea which plug it is then mate? :think:
DOD
by v6 steve » Thu Jan 06, 2011 10:02 pm
there cant be more than 1 or 2 pugs that go into the gearbox
by Calibra_Mike » Thu Jan 06, 2011 10:31 pm
as mentioned already, switch in gearbox... best advice I can give you... get a haynes manual, has helped me so much over the years...
by DOD » Thu Jan 06, 2011 10:39 pm
thanks guys will have a look over the weekend
DOD
by big_gordy » Fri Jan 07, 2011 2:00 am
this is it i think!
Tigra Chequers 1.6 - # 2 Car
by DOD » Fri Jan 07, 2011 9:54 am
thanks gordy
DOD
