Not firing....immobiliser?
Getting ECU light flash while trying to turn the engine over so, checked leads - got spark, got fuel pressure, all loom connectors are in the right places so wondering if a possible immobiliser fault is a read herring? (surely if it caused the engine light to flash I wouldn't have fuel or spark). The transponder hasn't had a fault before. Wont get to read the codes (if any) for a few days. So just wondering what ideas are bouncing about?
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: Not firing....immobiliser?
Flashing light does indicate immobiliser.
Hi,
This is weird,
Sorted it. It wasn't the immobiliser as I thought because the transponder worked before.
AML valve - low voltage and no rpm (expected) no signal to immobiliser (always had that code and no EML flash)
It stopped after I reconnected the broken AML valve wire. However, I broke it again while in that area so the EML is on permanently now but it's ok!
I'm just happy that I got the car started! so my rebuikd is nearly complete. Just need to sort the clutch!
Thanks guys
This is weird,
Thanks guys
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
The plugs were shot - after I changed them it was ok!
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
