CTS Sensor LET?
CTS Sensor LET?
by LE16 » Wed Mar 09, 2011 6:10 pm
hi,
Does anyone know if the CTS sensor can be faulty but not show a high/low voltage on the ECU fault codes?
Regards
S
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
Re: CTS Sensor LET?
by Fraz » Wed Mar 09, 2011 6:14 pm
if yoi think its faulty...............just change it they are only a few quid
Re: CTS Sensor LET?
by Vxlgsi » Wed Mar 09, 2011 10:17 pm
ive had more than one over the years thats been faulty out of the packet from vauxhall!!
Vxlgsi
Re: CTS Sensor LET?
by RobbieV » Wed Mar 09, 2011 10:20 pm
CTS Sensor does degrade in signal response with time, a failing CTS does not always raise a fault code it just provides the ECU with an incorrect coolant temperature. Will eventually supply a bad reading out of ECU tolerance (which is when a code is raised). Symptoms can include poor start, rough idle and rich running/poor petrol economy.
Re: CTS Sensor LET?
by LE16 » Fri Mar 11, 2011 5:05 pm
Cheers lads!
Seems to run bad when hot. Everything else (mechanical) is ok. No ECU code but its like a rocket when cool which makes me think CTS is out.
Will change tomorrow and update the thread.
Regards
S
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
