v6 supper chip
v6 supper chip
hi guys i fitted the super chip i bought ages ago it is four pins shorter than original everything works fine except oil pressure gauge it goes right over off the scale any ideas
carrollealn1
Re: v6 supper chip
That will be nothing to do with the chip that you fitted.
95% of the time the cause of the oil pressure gauge needle going off the scale is due to dirt, corrosion, or loose/broken connection at the sender.
Click here for oil pressure sender location picture
Try cleaning it first and securing the connector to the sender, if it looks dodgy.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
