vectra inlets on calibra loom help needed
has anyone put a msd engine in a calibra v6??? need help rewiring the butterfly valve from the four connectors to the two two connectors any help would be great many thanks
Toots01
Re: vectra inlets on calibra loom help needed
Im sure Ian has done his or he was doing it a while back, but will be on soon think it was him that told Ian how to do it
whats an MSD engine??
same as mine fraz but with the big inlets same as the vectra ones
I knew what the MSD engine is, but what's the MSD bit mean?
bodgetastic wrote:Motor Sport Developments
I thank you sir. I can sleep now.
More power than God
thanks for help will look at link does anyone know if their is a clearance issue as well?
Toots01
u can remove the butterflys and get a blanking plate same goes for the erg valve.
there will be a cleaance issue if u are using a stanared bonnet if u are u might need to lower the engine mounts mine all fits like a glove lol
still getting the bloody thing sorted i will let you know how it goes tho
ian
