Vectra b steering wheel
by Rocket » Sun May 20, 2012 2:08 pm
I fitted one to my calibra did it as the guide says on here now the airbag light wont go out has anyone else had this happen when swapping wheels ?
Rocket
Re: Vectra b steering wheel
by Callyman » Sun May 20, 2012 2:18 pm
*Moved to Technical/Electrical*
by v6 steve » Sun May 20, 2012 3:09 pm
if you turned on you ignition you'll need to get the car hooked up to a tech1 or a laptop to turn it off, did you connect it up again ?
by Rocket » Sun May 20, 2012 3:33 pm
Ive put my old wheel back on now what if i got a airbag ecu off ebay with know fault code ?
Rocket
by v6 steve » Sun May 20, 2012 3:35 pm
you will still need it pluged into a tech1 or laptop most garages can do it these days for you
by Rocket » Sun May 20, 2012 3:39 pm
I mite just send off the airbag ecu to a company that clears the codes off ?
Rocket
by v6 steve » Sun May 20, 2012 3:42 pm
Rocket wrote:I mite just send off the airbag ecu to a company that clears the codes off ?
wouldn't you be cheaper going to your local garage that does diagnostics
by Shaza » Sun May 20, 2012 5:47 pm
The light will need reseting with a tech1 or something similar whichever steering wheel you put back on!
We have a tech1 but your a bit far away lol
Shaza
My Old Turbo
Secretary & Merchandise Support
by Rocket » Sun May 20, 2012 6:59 pm
So if i put the vectra wheel back on then get the light reset will it stay out ??
Rocket
by Rocket » Sun May 20, 2012 9:42 pm
Yeah its all wired up right got the vectra squib etc cut the plug off the calibra squib them soldered it to the vectra one
Rocket
by Fraz » Sun May 20, 2012 10:06 pm
so you must have turned the ignition on before you had all the wires connected ??
by Rocket » Mon May 21, 2012 8:44 am
Nope i didn't i was super careful
Rocket
by big_gordy » Mon May 21, 2012 9:25 am
did u disconnect the battery BEFORE doing the work? if u didnt then as all people above said you will have to get a tech 1 or iirc something about leaving the battery disconected for just over an hour MAY clear it! but known me i will be wrong.... lol :pray:
Tigra Chequers 1.6 - # 2 Car
by Rocket » Mon May 21, 2012 4:06 pm
Yes i disconnected befor doing anything
Rocket
by Fraz » Mon May 21, 2012 6:48 pm
well the only way the light would come on ( I presume it was not on prior to the change?)
you have the wries incorrect or not fully connected
or you had the power on while the airbag was disconnectedcted
or the a part your fitting has a fault in it someplace
