Cooling Fan
Cooling Fan
The cooling fan on My V6 doesn't seem to be working. I suspect the fuse/relay is in the engine bay (as there is no fuse wiring present for it in the fuse box) - but which one is it?
Obviously I'll then check out the fan switch etc
1998 Calibra V6, 2001 Omega CDX Estate 2.6 V6, 1978 Triumph Spitfire 1500
Re: Cooling Fan
im sure its the big one in the wee black fuse box in the engine bay i would check the switch on the coolant bridge 1st
Re: Cooling Fan
What's the best way to test the switch Steve?
Re: Cooling Fan
Main radiator cooling fan - temp gauge going >100 and it's not kicking in.
Not sure whether its relevant but the alternator cooling fan kicks in fine
Re: Cooling Fan
check the radiator fan switch in the radiator as that maybe part of the problem,or you can buy a lower temp switch from LMF, so the fan cuts in at 82C
Re: Cooling Fan
Still struggling with this - something definitely not right when cold either, so would welcome a tad more guidance on how to test the various switches/relays mentioned above.
Re: Cooling Fan
Yes, has aircon (although non-functioning due to leak)
Re: Cooling Fan
Thanks, I will try this - I have visually checked all the fuses in the bulkhead but not sure which one is specific to the fans?
