Dash lights
Dash lights
by craigyboy » Fri Feb 08, 2013 3:53 pm
My engine management light and airbag light
are on.How do I go about cancelling them?
Re: Dash lights
by craigyboy » Fri Feb 08, 2013 6:00 pm
I'll go down and give it a try
looks a bit tricky
Re: Dash lights
by Fraz » Fri Feb 08, 2013 7:08 pm
would that not be the 4 digit Simtec code for the Ecotec rather than the 2 digit one
Re: Dash lights
by craigyboy » Fri Feb 08, 2013 7:20 pm
I'm getting ten flashes pause three flashes pause four flashes pause ten flashes pause
then over again
Re: Dash lights
by craigyboy » Fri Feb 08, 2013 7:43 pm
Cheers for that guys.Do I just have to change the cam sensor?
Re: Dash lights
by Fraz » Fri Feb 08, 2013 7:58 pm
Simtec do not get the codes cleared unless you use a reset tool Tech1 or something ...tried that 25 on off and never worked nor taking the battery off, only way is a tech1
Re: Dash lights
by craigyboy » Fri Feb 08, 2013 8:32 pm
I'll give it a try tomorrow and see what happens
Re: Dash lights
by Phill » Fri Feb 08, 2013 10:04 pm
I have a new one mate if you need it £15.00 . First have a look at the cable about 20 - 30cm back from the sensor. If it has wire crimps then check them first. I noticed the weather had got in and had corroded the crimps. I solderd on the new plug and cable that you get with the sensor and tried that first and it worked and its still working 5 years later.
Re: Dash lights
by craigyboy » Fri Feb 08, 2013 10:07 pm
When I check it tomorrow Phil I'll let you know ,cheers
Re: Dash lights
by craigyboy » Sat Feb 09, 2013 6:16 pm
Done the 25 times on and off with the ignition and its cleared
the fault. Thats a handy tip,thanks boys :handgestures-thumbup:
Re: Dash lights
by Fraz » Sat Feb 09, 2013 6:35 pm
that cleared the airbag light as well? and do you mean the ecu fault light is off now ...or you have checked and the code is cleared
Re: Dash lights
by craigyboy » Sat Feb 09, 2013 8:09 pm
The ecu light is now off but the air bag light is still on
Any ideas how to get this off?
Re: Dash lights
by v6 steve » Sat Feb 09, 2013 8:25 pm
youll need to get it turned off with a computer
Re: Dash lights
by craigyboy » Sat Feb 09, 2013 9:14 pm
are you the man for the job Steve?
Re: Dash lights
by v6 steve » Sun Feb 10, 2013 12:52 am
craigyboy wrote:are you the man for the job Steve?
i dont have the laptop youll need to speak to Mr T
