Tail lights
Tail lights
Both tail lights are not working and the indictor is on on the
dash board.Checked the lamps and theyre both ok.The rest
of the cluster is working fine.Has anyone any ideas how to fix this?
Re: Tail lights
Check and clean all the earth connections.
Tail lights
Have you had the clusters out recently?
Check that you haven't snagged any of the wires in the lighting loom
Sent from my iPhone using Tapatalk - now Free
Billing Banner Erection 2014
Billing Chef 2014
See my V6 Cally here
Billing Chef 2014
Re: Tail lights
The last time the lights were out was 2011 when it got resprayed
The earth is fine as the rest of the cluster is working.
Is there a relay on the tail side light circuit that could
have maybe worked loose? or are they straight from the
switch.The registration plate lights are ok
Re: Tail lights
Ive checked that again and it seems ok,ive even tried
another switch.I'm not getting 12v at the lampholder.
Does the circuit go through some sort of sensor to bring
the lamp on the dash?
Re: Tail lights
do you know if there is any joints in the loom from the
switch to the rear plugs?
Re: Tail lights
Is there enough petrol in it to make them work (sorry I'm bored mods can delete this if they want)
Re: Tail lights
Craig I think there's a connector or two on the passenger side when the loom runs to the back.[/quote]
thanks a lot for that, i,ll give that a check later on
Re: Tail lights
Got it fixed.The check control unit behind the glove box
multy plug was out at one side so just clicked it back in
cheers.
cheers.
Re: Tail lights
Well done pai
Tail lights
Glad you got to the bottom of it mate
Praise the Lowered !
