Fuse diagram
Fuse diagram
Can any one supply a diagram of the fuses and what amp each one should be, for a x20xev, having a few problem with some of the electrics and when I checked mine didn't match the fuses in toshs, some were different ie my tail lights were 5 and 7.5 both his were 10. Thanks
Terry
Terry
Re: Fuse diagram
Smashing that's great many thanks, I'm struggling to get my reverse light to work, not sure which fuse it is nor what amp should it be either, iv changed the bulbs so it's not that, so I want to eliminate the fuses then start digging more
Terry
Terry
Re: Fuse diagram
It could be the switch on the front of the gearbox mate.
Re: Fuse diagram
Do you have a pic of where this switch is? Iv not got my Cally haynes manual at the moment to root through it, iv also gathered more information on fuse box so if it's ok with admin I'll write this up.
Terry
Terry
Re: Fuse diagram
Tkeenan2107 wrote:Do you have a pic of where this switch is? Iv not got my Cally haynes manual at the moment to root through it, iv also gathered more information on fuse box so if it's ok with admin I'll write this up.
how too's are always welcome
Re: Fuse diagram
Thanks,
Steve can you check the other thread, if you or others would like to keep it as a sticky that would be great think it's something that always comes in hand now and again.
Terry
Terry
Re: Fuse diagram
Its a two pin plug.Bridge it out and the lights
should come on.If so then you'll know the switch
is at fault.
is at fault.
Re: Fuse diagram
I'll try my best to find it, it will be stood till Boxing Day now but if anyone in the mean time ends up going under the bonnet and there able supply / provide a picture of the location that would be great.
Terry
Terry
Re: Fuse diagram
After having a look through the old Haynes manual and can I for the life of me find anything about a switch of the gearbox, really would appreciate it if anyone has any pics of the location, as I'm having a lot of problems with her at the minute so what to start crossing things off the list. Picked up some fuses today to check all the fuses tomorrow, but iv got a right list of problems, so looking to start working my way through as best as I can.
Terry
Terry
Re: Fuse diagram
many thanks, what sort of switch it is? Twist it looks like? Or flick? Can't thank you enough very much appreciated.
Terry
Terry
Terry
Terry
Re: Fuse diagram
Fantastic great stuff, thanks for your help.
Terry
Terry
Re: Fuse diagram
Hi just a quick update, tried the paper clip test on the reverse switch and it looks like iv a faulty switch, before doing the test sprayed both connections with some contact cleaner too, so just have to add this to many of the problems im slowly discovering.
Thanks again for your help.
Terry
Terry
