Fuel pump not working
by James_Mould » Thu Jun 11, 2015 8:40 pm
Today when I started my car I noticed it took a few turns of the key to get it to start. The fuel pump has stopped making the whurring noise when ignition is switched on. Ive checked the relay and it clicks in when the ignition is turned on. The fuel pump is working as I shorted out pins 30 and 87b on the relay and the fuel pump runs. 87b (red and blue wire to fuel pump is showing no voltage when relay clicks in but pins 85b and 87 show 12 volts when ignition is turned on.
Is there anything else I should be looking for before I go and buy a new relay?
Ive also pined out the signal wires to ecu and everything seems to be ok there.
Magnetic blue SE8
Diamond black turbo 4x4
Re: Fuel pump not working
by Allys Cally » Thu Jun 11, 2015 8:47 pm
rather than going and buying one, could you not get a loan of a known working one off a member (Markv6) just to rule it out mate :wink:
by v6 steve » Thu Jun 11, 2015 8:48 pm
sounds like youv answered your own question already now go buy a new relay
by v6 steve » Thu Jun 11, 2015 8:50 pm
didnt you sell the se8 ? what relay you got i might have one in shed
by James_Mould » Thu Jun 11, 2015 8:58 pm
v6 steve wrote:sounds like youv answered your own question already now go buy a new relay
I thought so Steve I just wanted to make sure.
Allys Cally wrote:rather than going and buying one, could you not get a loan of a known working one off a member (Markv6) just to rule it out mate :wink:
Hopefully someone is going to lend me one tomorrow whos got a couple of Omegas just to make sure.
v6 steve wrote:didnt you sell the se8 ? what relay you got i might have one in shed
Yeah I sold my SE8 and it got brken up :twisted: The relay is a the single black one part no. 90378651
Magnetic blue SE8
by sealeysonic » Fri Jun 12, 2015 8:52 am
If im right dont the relay click twice....1st prime the fuel line....2nd pump run....?
by James_Mould » Fri Jun 12, 2015 8:35 pm
Ive tried a known working realy today and its still not working. Looks like I will be urapping the wiring this weekend to try and fin the fault.
Ive also dropped the tank now and found the plate for the the fuel pipes has corroded and the fuel feed pioe is completely loose in the he plate. Looks like I will be making a new one out of stainless next week.
Magnetic blue SE8
by sealeysonic » Fri Jun 12, 2015 8:38 pm
Oh dear...not good....did u wire up a 12v feed to the pump to see if it ran?
by James_Mould » Fri Jun 12, 2015 8:43 pm
Yeah Ive done that Mark and pump runs fine. I didi it that way to empty the tank of fuel before dropping the fuel tank. I will be fitting a Walbro HP pump while Ive got tank off anyway.
Magnetic blue SE8
by sealeysonic » Fri Jun 12, 2015 8:44 pm
Take some pictures please for my reference ;-)
by James_Mould » Sat Jun 13, 2015 11:30 am
Yes the car starts and runs no problem when I bypass the relay. The first stage of the relay pulls in no problem to power the injectors, senssors and signal to ECU. Theres just no power to pump (prime) when ignition is turned on.
Magnetic blue SE8
Users browsing this forum: No registered users and 68 guests
